I am using a SS-XXX10K and I have good electric as well as Mechman voltage boost module to keep my voltage up at 16 volts. My question is can this amp run at .5 ohms on 16 volts? I am anticipating box rise so my guess is I should be just under 1 ohm when slappin. I have heard mixed opinions about this. This guy on Youtube is
running it at .5 ohms on good current but bad voltage and the amp got hot without really pushing it hard so will the amp do it daily no issues. Edited by Bam Bam
6 Funky Pup 12's
define good electrical.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What exactly does slappin mean? Also you cant get a good answer to your question unless we know exactly what you are running for electrical. I'm hoping your running a 14v batteries if your charging at 16v cause that's not good for 12v batteries.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
Slappin or Beating.
I have 3 Stinger SP2150 in back and a Optima battery under the hood. I have a dual alturnator setup 270 amp Mechman and a stock 130 amp. I adjust the voltage module when I am need more volts and run it hard. In most cases the system will charge and remain steady at 14.7-15.4 volts. I will kick it up to 16.5 volts when i'm clowning.
Edited by Bam Bam
6 Funky Pup 12's
the only thing I can see is it draws 550 amps of current. if thats the case its uber efficient but at .5 it will draw almost double that. you would really be rolling the dice if you tried it they arent exactly the most stable to begin with.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so are letting 12 volt battery charge at 16 volts? 0.o
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
No. the batteries see around 14.7-15.3 volts. When I really want to push it hard I adjust the module up to 16 volts. I usually run it like this for a fees hours batteries are not constantly seeing 16 volts.
6 Funky Pup 12's
hmm so that is still bad/hard on them y not just do a 14 volt system
Need the money to replace the batteries. Stock Alturnators for my vehicle usualyy charge at 14.2-14.4 volts so it is not excessively high until I raise it to 16 volts.
6 Funky Pup 12's
im done here
16 volt even for a lil bit is hard and bad for 12 volt battery
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
