MTTornquist's Corolla SQ Build *now with Linear Power 11/26
As long as you don't have a sub, you can match the other channel (40 Hz, but can't see if the cross over is activated at all). If you lose on bass you need to change the phase of your speakers (reverse + and - for the speakers till optimum sound is reached).
When adding a sub you can turn the frequency up to where the sub cuts off. That way you save the compo's from some unnecessary stress.
Woofer: 12" Phase Linear Aliante Limited
Mids & highs: DLS Ultimate 5 1/4"
Amp: Audison VRX 6.420
HU: Sony CDX-C90R
Okay that kindof confused me. You are saying to turn the f1 curve down so that the front conponets are seeing the bassline as well? Won't that cause them to bottom out and could potentially blow them?
If it does risk the speakers then I am fine not having bass for a couple of weeks until the sub gets here
Alright so my sub should be here in about 2-3 weeks and I'm working on a final box design.
I ordered an Ascendant Audio Assassin 10 and am getting it custom built with a single 4 ohm coil configuration.
Here is what I am thinking:
Would be front firing with the trunk sealed off. :good:
Thanks for reading, be sure to comment with your thoughts!
  • 3 weeks later...
Sub should be here in about a week meanwhile I've been working on the design more, decided I'm doing an areo port tuned lowwww.
Threw it in inventor and here's what I'm thinking:
Shot at 2012-08-01
Shot at 2012-08-01
Excited for the sub to get here and to get building!!
got quite a bit of work done in the last couple of days.
Got two 4x4 sheets of mdf; it was cheaper then a full sheet, idk why but it was cool.
So i dont have any friends with pickups so you have to make do with what you have. haha
then got a good start on the box today:
Then here is my 4 inch pvc and fittings. this stuff was expensive! holy cow
thats all for now.
except for one little suprise:
So excited about this amp!
Picked her up brand new! :)
the sub will be here tomorrow!!!
Thanks for checking in!
No, we did not glue the PVC pipe fittings so we could adjust them during final installation ... but I can guarantee you that they will not move from there present location ...
How many inches of PVC is your enclousure calling for ?? and what will be your final tuning frequiency ??
There will be 3 sections of pvc, two of them are about 3 inches just to connect the elbows together and the other is about a foot and a half across the width of the box.
Final tuning will be right around 28.2xx
Should I make the top removable so I can change it around more easily?
Might not be a bad idea at first for trial and error ...
Alright thank you that is what I will do!
Anyways got another little something in the mail today!! :good:
Ascendant Audio Assassin 10 custom built with a single 4 ohm coil!
This thing looks like a little beast! :)
So happy with the sub, well worth the wait!
Thanks for looking, show me some more love forum!
Very nice driver
