brucesmith Posted June 18, 2012 Report Share Posted June 18, 2012 Hello, I have a Pioneer TS-W256c 10" sub that I'm planning on building a L ported box. But I wasn't really sure of how wide to make the port. If anyone could hook me up with some dimensions that would be good for my sub please let me know. Also how thick of MDF should I use? Also this is the amp. http://www.sonicelectronix.com/item_3706_Phoenix-Gold-R2.0-1-Octane-R-2.0-1.html just in case that makes a difference or not. Thanks in advance for the help. This will be my first time building a box by the way. Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 19, 2012 Report Share Posted June 19, 2012 3/4" MDF would would fine, look up Torres Claculator on this site, download it and design your own box per the specs that are recommended for that sub. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Joe X Posted June 19, 2012 Report Share Posted June 19, 2012 You could try this: Enclosure Specifications: Fb = 34 Hz Vb = 1.25 ft^3 External Height = 12 in External Width = 17 in External Depth = 20 in Port Width = 1 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 14 1/2 x 10 1/2 Back = 17 x 10 1/2 Left & Right Sides: Side 1 = 18 1/2 x 10 1/2 Side 2 = 19 1/4 x 10 1/2 Top & Bottom = 17 x 20 L Port Internal Assembly Parts: Front to Back = 16 3/4 x 10 1/2 Extension = 9 x 10 1/2 Assembly guide (generic dimensions): Quote Link to comment Share on other sites More sharing options...
brucesmith Posted June 19, 2012 Author Report Share Posted June 19, 2012 Thank you alot. I will probably use that. Quote Link to comment Share on other sites More sharing options...
