srool Posted June 19, 2012 Report Share Posted June 19, 2012 Hello ! I have 2005 subaru impreza, it's sedan, and every subwoofer I put in the trunk sounds few DB less loud than Hatchback or SUV. Putting the enclosure on the rear seats doesn't make it powerfull as it can be. someone told me about sealing the wall between the trunk and the rear seats. Is that right ? Is there a way to make the bass be as loud as the potencial fot the products? Thanks ! Quote Link to comment Share on other sites More sharing options...
Cardboardcat15 Posted June 19, 2012 Report Share Posted June 19, 2012 Wall it. lol Just tossing a sub in a box on the back seat wont make you loud. Doing a box firing into the cabin that is SEALED off from the trunk works well, but only if you have folding seats. IIRC, there's a build on here somewhere where the guy ported through the rear deck of his mazda and got great results. Quote My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
Kevin M Posted June 19, 2012 Report Share Posted June 19, 2012 You can wall it like he mentioned. You can also add more cone area or more power or both lol. That will give you more output. Quote 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle Link to comment Share on other sites More sharing options...
Omega5002 Posted June 19, 2012 Report Share Posted June 19, 2012 Yeah, either wall the car to get the most output, or if you want all your seats, face the box forward, seal it from the trunk so all the bass goes inside the cabin area, and fold down the back seats if possible. Quote 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 19, 2012 Report Share Posted June 19, 2012 (edited) i have only found 1 car that worked well for subs in the trunk , it was a buick park ave , something about that body was awsome for subs in the trunk . if you don't want to do a wall you could do a 4th order bandpass Edited June 19, 2012 by b-dubs89 Quote Link to comment Share on other sites More sharing options...
RivalKarl Posted June 20, 2012 Report Share Posted June 20, 2012 most of the time hatchbacks and suvs will be louder than trunk cars...just how it is....if you want it to be louder do as mentioned...either wall or seal trunk or add more cone area/power. Quote Current system(In Progress) 2002 Dodge Grand Caravan Subs-16 Rival Mobile Electronics C15.22 subs. Sub Amp-1 Sundown Audio NS-1(eventually 2) Mids-Undecided Mid Amp-Undecided Batteries-6 Shuriken BT140's Alt- 320amp MECHMAN alternator Tsunami Wiring Link to comment Share on other sites More sharing options...
Born_Again Posted June 20, 2012 Report Share Posted June 20, 2012 Do your rear seats fold down? Quote Link to comment Share on other sites More sharing options...
srool Posted June 20, 2012 Author Report Share Posted June 20, 2012 My seats won't fall down, but I'm working on changing it what if I'll make a box which will be in the trunk but the subwoofers and port would be firing into the rear seats area, and there would be a fully separation between the trunk and car? Quote Link to comment Share on other sites More sharing options...
TigerTony Posted June 20, 2012 Report Share Posted June 20, 2012 My seats in my car don't fold down either.. I have mine Sub back port back and then my rear deck speakers removed so air moves through the holes where the speakers were. my next box will be ported through the deck. You should try that if you intend to keep your backseat. But sorry if that wasn't what you meant by firing into the rear seats area. Mostly from what i've learnt is that its not as loud trying to fire through the seat. Quote Link to comment Share on other sites More sharing options...
