heydude348 Posted June 20, 2012 Report Posted June 20, 2012 I know it's been asked a thousand(or more) times but which will be better for a full range of music/ Rock,Rap, hip hop,etc. I will be running 2 JL 10W7's. Each will have a JL 500/1. When I bought the speakers, second hand, they were in a single box/ported.I cut the box in half( first because it would not fit in the car and secondly because I wanted to do a little testing to see which would sound better) and know one is 23 1/2 x 13 3/4 x 14 3/4.All outside dimensions.3/4" MDF.Slot ported.The second box is 18 1/2 x 14 3/4 x 13 3/4. Outside dimensions.Sealed.If my calculations are correct the first nets-2.066.And the second nets-1.597. If I've missed something feel free to correct me. By those calculations it seems like the first is off by JL recommendations by more than .25 cu.ft. Like I said I bought he box already maid. The second one I made , which was the remainder of the first, I cut down and sealed . I know it's long winded but the end is near. Assuming I correct the specs on the ported design, which one will give me the best all around sound? Also, I did not take into account the air space the sub displaces.
Guest Posted June 20, 2012 Report Posted June 20, 2012 we cant know the precise box size of ported boxes without knowing the dimensions of the port edit: i'd just do a proper ported box. in my opinion
Cardboardcat15 Posted June 20, 2012 Report Posted June 20, 2012 I would only do sealed if there was a space restraint. That, or if there's a shit ton of power and cone area. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
MrSkippyJ Posted June 20, 2012 Report Posted June 20, 2012 a propper ported enclosure can sound good with any music. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
