BumpinLow Posted November 5, 2006 Report Posted November 5, 2006 Well...I had an RE 12.1 and it worked just fine when I pulled it out of my truck. I sold it to this kid, helped him hook it up and everything and it won't play for shit in his ride. I pulled it out, put in a JL 250/1 and that worked just fine. I'm seriously confused as hell. He has 2 dual 4 ohm type R's, so wired down to 1 ohm and it barely beats. I checked the RCA's, LPF and HPF, speaker wire...I'm seriously lost. Especially since with everything done up properly, the 250/1 works and the 12.1 doesn't. Quote
AI James Posted November 5, 2006 Report Posted November 5, 2006 why aint you check it on your setup, or did you already rip all wires out Quote
andym85 Posted November 5, 2006 Report Posted November 5, 2006 huh...wierd. i would try and do like accordman said and see if you can hook it up to your system again, if you havent already tore the wires out. the gains up on the amp? maybe bace rca inputs? Quote i likes me some audio stuff...
BumpinLow Posted November 5, 2006 Author Report Posted November 5, 2006 All the wires are out of my truck, gains were fine, RCA's were fine. I'm seriously lost. Quote
Guest MegaloManiac Posted November 6, 2006 Report Posted November 6, 2006 you probally just need to reset the amp. basically what you do is un plug the amp just the power and ground. and then short the 2 terminals to discharge it. then hook it back up and try it. that happened to me on my 4channel Avionixx. Quote
AI James Posted November 10, 2006 Report Posted November 10, 2006 lol i totally woulnt recommend that on those POS RE amps, you tell someone from RE that you shorted somethign out trying to fix it and they are gonna look at you like your an idiot Quote
Guest MegaloManiac Posted November 10, 2006 Report Posted November 10, 2006 lol i totally woulnt recommend that on those POS RE amps, you tell someone from RE that you shorted somethign out trying to fix it and they are gonna look at you like your an idiot but thats how you reset them...atleast the Avionixx and eD amps Quote
AI James Posted November 10, 2006 Report Posted November 10, 2006 i believe those amps are made by the same people, RE,s arent Quote
Guest MegaloManiac Posted November 10, 2006 Report Posted November 10, 2006 although they might look similar eD has a differnet builder for their amps, same soft parts but completely differnt boards. the internals are dissappointing on the eD amps, except the NINe 1 Quote
