wiring 2 dual 1ohm subs to 2ohm load
hey guys. when i went to pick up my subs, noticed the company made a mistake of sending me dual 1ohm subs instead of dual 2ohm subs.
how do you wire up 2 dual 1ohm subs to a 2 ohm load.
thanks
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
how many subs are you going to run ?? series each sub for a 2 ohm load
Edited by Cablguy184
im running 2. i know its possiable cause i watched the guy where i picked them up wire it to a 2ohm load and put a DMM to it. read 2.2 on it. i just can not for the life of me remember how he had it wired.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
series
ground from your amp to the neg of onee side of sub ... jumper from pos of that side to the neg of the other side of the sub ... the pos back to the amp ...
2 ohm load per sub ...
treo ssx 12'. read 1.5 by them selfs.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
series
I think he's wiring two dual 1 ohm subs.
2015 Subaru Outback. That is all, I refuse to touch it.
yes, wiring the subs in series, then aprellel to each other will give a one ohm load to the amp ...
Yes there dual 1 ohm subs. I need a final load of 2 ohm to the amp. So 2 dual 1ohm subs to a 2 ohm load on one amp. The amps are strapped so they need a 2ohm load
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
  • Who's Online   1 Member, 0 Anonymous, 1582 Guests (See full list)
