here is some basic pics of how i am starting to do my highs, it is all soundstream sst, 6.5' so far
i have two sets of the memphis m_class tweeters also. i wanted two 6.5s per door but i am going to put more it is a start.
i took more pics but have to get them from work, i had to cut metal out from the door, make an mdf plate and cut to fit and trim it
i will post more pics as it goes.
High Amperage Audio
DC Sound Dealer
Sun down audio dealer
Anything you need hit me up
What more do you need than them!!
got some more goodies to go in, Memphis M- class tweeters installed cut into door, Dont have pics yet and right behind factory a piller spot that the normal tweeters come in,,,sound great so far, with two 6.5's in each door and complete second skin in the doors , they have a good amount of bass going to them.
going to put one more 6.5 in the front somewhere, also made the same kind of plate for the rear doors. just for one 6.5 to go into them
here is some pics of new stuff today
High Amperage Audio
DC Sound Dealer
i think they sounds great, very good amount of bass and very clear, they sound the same to me as my memphis m-class i had in there
they have the same type crossover and cost alot less
High Amperage Audio
DC Sound Dealer
6x9's are going in the back somewhere, just a get loud setup not for sq
got two more packages in today, needed a little power
couple of 300 amps should help, with small pulley should do good
High Amperage Audio
DC Sound Dealer
i will post some more tonight, basically what i did, was take the grill off draw it on cardboard. then cut a piece of half inch mdf out.
and use my sander to shape it just right. cut the two hole then draw it on the inside the door and cut out the metal behind there.
very tricky as the window motor is right there also. wrap it and 4 screws from the back and there ya go.
High Amperage Audio
DC Sound Dealer
nice, SS make some good shit, esp. tarantula series, look good and go good :P, keep up the good work :P
1 12 inch infinity 1240watts...only can fit that in a hilux single cab...
1 infinity 1000 watt mono block...
2 Hifonics Zues 6.5" Components
2 Hifonics Zues Tweeters
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
