Redcorn245 Posted June 24, 2012 Report Posted June 24, 2012 Why do you turn all your equlizer settings on low when you tune. Dosent your voltage go up when you turn those things back up? It will bring it closer to clipping won't it?
BobbyG2 Posted June 24, 2012 Report Posted June 24, 2012 Turn all your Headunit equalizer settings on Flat, and keep it that way after tuning. *New vehicle and system coming soon.*
Redcorn245 Posted June 24, 2012 Author Report Posted June 24, 2012 Turn all your Headunit equalizer settings on Flat, and keep it that way after tuning. Really? It doesn't sound that good. Even tho Im not even close to my voltage. I should just tune with my amp then?
BobbyG2 Posted June 24, 2012 Report Posted June 24, 2012 If you turn up your equalizers after tuning, you'll clip that those frequencies. But, as long as you realize that and take it easy, don't play full tilt all day long, you should be fine. *New vehicle and system coming soon.*
Redcorn245 Posted June 24, 2012 Author Report Posted June 24, 2012 Well i only tuned my amp to 25 volts and that is like 10 volts lower then it should be so i would be side. I wish i knew exactly how to do it
95legwagon Posted June 24, 2012 Report Posted June 24, 2012 the DMM method isnt accurate and theres still a chance your clipping anyways.... just sayin i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Redcorn245 Posted June 24, 2012 Author Report Posted June 24, 2012 the DMM method isnt accurate and theres still a chance your clipping anyways.... just sayin So should i just tune it by ear? Its not distorting at all
