Sundow Z v.3 15 Box Help
Make the brace closer to the sub cutout, and do a vertical one as well to brace the top/bottom of the box. There are 1.25" dowels at Home Depot.
Alright will do. Is the 4" space between the end of the port wall and the side of the box going to be ok?
It looks good...between the double baffle and rod should be sturdy...Are you going to Resin/fiberglass the inside at all?
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
Ok it took some crunching lol but how is this.
SPECS:
BOX:
What do you think. The only thing I can think of is only having 4" between end of port and the side wall. Will that be ok since its larger than the 3" port width? Also I dont know how to do 45's on sketchup but I figured there would be 3-4. 2, 45's along the back two corners(in port area), 1 right behind the sub, and maybe 1 on the front wall( right of the sub cut out) depending on what you guys think.
EDIT: This box is 2.53 cubes, 34.40 hz, and 18.99 sq". It's kinda small to read.
OK so learned some new sketch up tricks and decided to do some finishing touches on my box. So here it is. I will start building it over this weekend and next week( since I get all next week off for the 4th of July :drink40: ). What do you guys think? All measurements are the same just rounded edges, 45's, and bracing.
Edited by tlh_360
If your port center line length is 36" then the internal port parts should be:
L Port Internal Assembly Parts:
Front to Back = 11 x 16
Extension = 19 3/4 x 16
Not much of a big deal but you may want to know.
well the front to back is 11 but how is the extention 19 3/4? that would be 30 3/4 + the 1 1/2 baffle is only 32 1/4.
right now its front to back 11 + extension 23 1/2 + the baffle 1 1/2 = 36
  • Who's Online   1 Member, 0 Anonymous, 965 Guests (See full list)
