Question regarding hz of ported enclosures
I'm not sure if I'm asking this question right..but.. Say you have a box tuned to 35hz, how low will it actually play? Or 30hz? Is there a formula to figure it out?
You are looking for the F3 point, there is a formula but it doesn't work inside a car due to cabin gain, the in car F3 will be lower than outside. When you tune high usually the box/sub response will peak a lot, that will make harder for you to listen frequencies above and below the range of frequencies where the peak occurs. Normally tuning lower will result in all frequencies being being played more evenly.
Tell me everything about your car box and sub and I could provide a raw (very) estimate.
When you say car..what do you mean exactly? And.. My box is 38"wide, 28" deep, and 14.75" tall with a 4.5" port tuned to 33.5 hz with 2 SA15s on a Soundstream TX.2000D. If that helps at all
  • Who's Online   0 Members, 0 Anonymous, 1133 Guests (See full list)
