So I just tried to install my new clarion equalizer and it turns on and everything, but fails to control the volume control and equalizer setting. I will explain my wiring, and hopefully someone may have a solution? Right now my deck is a sony cdx-gt56ui with only one pair of RCA outs on the back. I hooked the equalizers main auxiliary in from the head unit's one pair, and that didn't work, so i eventually just tried every single input on the back of the equalizer (sub, main, aux, front, rear) and none of them worked still. For my power, ground, and remote wiring: I have a solid no spliced wire coming straight from the battery for the 12v connection. my ground is spliced with my head units ground. and my remote is spliced with my sub amplifier remote. The only conclusion I could come up with is that my deck's RCA's are just refusing to work with the EQ because its not a high quality deck, but thats all I could come up with. Your help is appreciated, thanks.
Is the EQ hooked up to any other amp? It should be.... Head unit RCA to EQ, then another set of RCA's to either a sub amp, or an amp for the door speakers, or both. Whatever you have.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
yes, I had it hooked up to a sub amp but still wouldn't work. And shouldn't the equalizer be able to tune the speakers running off the head unit or no?
No. How the hell would it do that?
What exactly do you mean when you say it doesn't work? Does it turn on? Do you get any sound at all from your subs?
Is there a setting on the head unit to switch the RCA output between sub and rear? If so, switch that setting, see if that works.
And make sure the volume on the eq is up, same with the sub level.
The equalizer lights up, but does not control the volume of anything, even when i had the RCA's from sub out to my sub amp and the head unit's rca's to the main aux in.
The EQ won't tune your mids off the headunit or control the volume, you'd need a seperate amp for that.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
  • Who's Online   0 Members, 0 Anonymous, 974 Guests (See full list)
