subwoofer ported enclosure help
so i have recently(2 hours ago) bought a
fi ssd 10 dual 1 ohm - running at 1000 rms
and a MB Quart ONX1.1000D - running at 1000 rms at 1 ohm
the car i have is a 2001 toyota echo
so now i need to figure out if i should build a box or use the bassworx ported enclosure that came with my Kicker C104 (150 rms)
***may i add i dont know how big the box is.. and i dont have a tape measure handy at this point***
the fi ssd 10
Ported box: .6-1.2 cuft @ 33Hz
kicker
1.25 - 1.75 cubic feet ( doesnt say at what frequency)
any help would be wonderful
and a side question
capacitor or battery??? ill probably need one or the other...
you cant run a dual 1 ohm sub at 1 ohm kiddo
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
You should build your own box to get the best results.
Battery definitely, they help alot more than a capacitor when needing extra power, or having to deal with voltage drops. Big 3 is recommended as well if you haven't done it.
You're gonna have to either wire that sub to 2 or .5 ohms, and I don't know if the MB Quart can handle .5 ohms.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
as long as you arent wiring at .5ohms, i personally wouldnt bother adding a batt. pretty much any stock electrical can handle that amp. an extra batt def wouldnt hurt any though!
and to me, big 3 is a must in ANY vehical, whether it has a system or not. thats just me though.
2005 Subaru Impreza
My build log.
thanks omega your response actually helped unlike ab18vvfl ( well his first post :) ) and sounds good , ill try it out first then in two weeks when i get paid buy a battery, and ill end up doing the big three as well.
do you know where i could get a good enclosure idea for this sub? and ill probably run at 2 ohms
and for the second post by ab18wfl thanks for the help i really didnt wana have to buy a new battery and ive only had my car for 4 weeks kinda still need money for all these upgrades
why didnt my first post help you? the SSD is gonna want ALOT more than 500 or 600 watts at 2 ohms...
2005 Subaru Impreza
My build log.
His post wasn't helpful?? God knows how you would have wired it if no one said anything...
If you just ordered that sub 2 hours ago, contact Fi and see if you can change your order to dual 2 ohm.
The ONX1.1000D will deliver 750W (they say) at 2 ohm and it won't be a night and day difference in output BUT you can call them and get the dual 2 ohm, that will be better.
Usually Kicker boxes are tuned high and likely won't be optimal or that sub, build your own, post some dims and me or others can get you a cut sheet.
Edited by Joe X
The amp is gonna be more efficient at 2 ohms then 1 ohms, which is very normal for amps, so electrical shouldn't be too bad but Big 3 is a big definitely, and 750 watts should be fine for the SSD, you're not gonna horribly under power it.
This is a very helpful tutorial on designing a ported box
http://www.stevemeadedesigns.com/board/topic/145174-ported-box-design-a-tutorial/
And there's Torre's calculator topic as well for more details
http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator/
2003 Kia Sorento
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
