Cazz Posted June 28, 2012 Author Report Posted June 28, 2012 I finally got something right, I won't be answering for around 6Hrs so surprise me when I get back.
john253a Posted June 28, 2012 Report Posted June 28, 2012 the only way i could get it to work in what you have is with aero ports if you are going to use psp port 15.25" and 16.25" overall i allowed for 1-1.25" round wood for bracing,(2 front/back, 2 left/right, 4 top/bottom, but 1 side, 1 back and 2 top will be fine) and if you want to use normal pvc and put a bend in it
Cazz Posted June 28, 2012 Author Report Posted June 28, 2012 The maximum size the box can be is: Width: 32" Height: 18" Bottom Depth: 36" Top Depth: 28" Does this help? Edit: That's the size of the boot but because a slanted back on a box is awkward use these dimensions: Width: 32" Height: 14" Depth: 28" Edit: Also above the 2 front/back and the round wood thing is confusing to me but the box with the dimensions my dad could put it together easily because he's a Carpenter.
john253a Posted June 28, 2012 Report Posted June 28, 2012 just increase the box height by 0.75 to allow the extra baffle and youll be fine 2x4" psp ports is plenty for thoes subs
john253a Posted June 28, 2012 Report Posted June 28, 2012 http://www.psp-inc.com/ they also sell on amazon and a few other places
Cazz Posted June 28, 2012 Author Report Posted June 28, 2012 The picture you posted of the box you designed, is that tuned to 33Hz?
Cazz Posted June 28, 2012 Author Report Posted June 28, 2012 The Port Length is in inches so if it was 23 I would have to have the left port going in 18" and turning left 90 degrees for 5" and the same for the right except turning right? Correct or completely wrong?
john253a Posted June 29, 2012 Report Posted June 29, 2012 Not quite, it's still down the centre to the middle of the bend and down the centre on the way out So the 2 straight pieces should be around 20" But you could tune higher if you want, and if you don't like add the 90 and extishion,
