Cazz Posted June 29, 2012 Author Report Posted June 29, 2012 So what is the box you designed tuned to? Because if you don't mine could I use it? I would prefer 33HZ but I know im not going to make a better one then that.
john253a Posted June 29, 2012 Report Posted June 29, 2012 In the Torres I put with the box There is 2 different ones but both are the same box just different length ports
Cazz Posted June 29, 2012 Author Report Posted June 29, 2012 So how will I fit a 23" port in a 20" box? also do you mind if I use it?
Cazz Posted June 29, 2012 Author Report Posted June 29, 2012 Can you write how far in the ports are from the side and from the top, that is if you dont mind me using your design.
Cazz Posted July 3, 2012 Author Report Posted July 3, 2012 Thanks, but I wasn't sure if you made it to show me how to use Torres.
