havent seen a 15 before, but depending on how long you can get the console, 2 8s would give you a good amount of output with small enclosure volume and a smaller port.
That would work depending on what are the max dimensions you have to work with
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
You can do it, I would run the sub at a slant facing upwards towards dash in front and split the port and have two sections go behind each seat. It would look like this from the top...T
It would load well off each corner behind you and passenger. Each side running behind each seat could be say 2in wide and 15in tall. That would give 60in port ....Shouldn't hurt leag room
Edited by SWIFT
2012 F250 Lariat 6.7, lifted on 22's and 35's
4 DSS Ethos 18's walled tuned low
2 Ampere Audio 7500.1's, Ampere 125.4
Rockford Pro Audio front stage
9 batteries, Mechman Elite 370 alt
Team DSS, Team Ampere Audio
2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
32d73d87-e373-4a49-8914-d25decfa6dcc_zps
I've done two 10's face down in a sealed enclosure in a reg cab f-150, The console even had room in the top and a lid, for storage of stuff. Not sure how you would cram a 15 in a compact though...Maybe with some fancy fiberglass work you could do it.
Thinking outside the box I like it! :detail:
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(1) Audio Control Line Driver
(4) DC LVL 4 15's
Cresendo Mids and Highs
100' of 0/guage
Big Three
Mechman 270a Charging @ 16.5v
(6) XS D1400's
Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1
Updated JUNE 2012*****MY BUILD LOG
USACI REGION 6 POINTS LEADER 2011
USACI KANSAS RECORD HOLDER 2011
Team DC
http://www.dcsoundlab.com/
  • Who's Online   0 Members, 0 Anonymous, 850 Guests (See full list)
