Is this good? http://item.mobileweb.ebay.com/viewitem?itemId=200555955732&index=4&nav=SEARCH&nid=43884545550. Or is this better? http://item.mobileweb.ebay.com/viewitem?itemId=180869636182&index=2&nav=SEARCH&nid=01107475961. Or is their anything better or different I need to look at?
Edited by liftedz71withbass
05 trailblazer
Sub-3 Aq hdc3 18 with psi recones (need motors hmu)
Sub amps- 2 Lanzar opti 3200
153.1
1/0 welding
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
If budget permits go with any 1/0 awg oxygen free copper wire (better to go bigger that way if you plan on upgrading your setup in the future you already have the wire to support it). Google search some more but if you're going to buy "1/0" make sure it at least meets the AWG specs. Welding wire is less expensive and works well.
How much power are you planning on running? Make sure you have enough to wire your amps and for the big 3.
http://www.ebay.com/itm/Rockford-Fosgate-RFK1-1-0-Gauge-Amplifier-Install-Kit-Made-Of-100-Pure-Crystal-/390408595058?pt=US_Car_Audio_Video_Amplifier_Kits&hash=item5ae62a6672#ht_2863wt_1139
not sure how much wire you need , but given the wire you are looking at costs $70 for 50 ft if you only need enough to do one run this kit from rf should be cost effective . i have the big dual amp 0 gauge kit from rf and i think their wire is good
Don't need amp kit just need 2 msybe 3 positive runs to the back and ground battery in back to frame maybe a run Of negative tO the front. Plan on running 3k with plans to add more in the future. Would a 50ft roll of the knu kolosus be worth the 50$ extra over the 50ft of welding cable?
05 trailblazer
153.1
It depends on the wwelding cable. I'm not sure what brand but the knu is thicker and has a higher strand count so its more flexible. How tight is the install and that could help you decide. Look up coppercableman on ebay. He has Trystar cable thats welding cable but it has an inner sheath that makes stripping clean way easier. I have used about 50ft before on friends installs and its plenty flexible.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
Defiantly go with knuconceptz wire. Over the best for the cheapest.
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
  • Who's Online   0 Members, 0 Anonymous, 2492 Guests (See full list)
