simplemindz Posted July 11, 2012 Author Report Share Posted July 11, 2012 My other problem is that when i usually cut wood for my vehicle. Is that a sheet of wood is 49 x 97. So i leave all my cuts at 49in so when i add the sides that go on the outside of the top and bottom sheets, that's what adds for it to be at 50.5 at the width for the extra 1.5 inch from the sides. If i cut the wood how it says on your cut out sheet then I'll have to get more wood Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 11, 2012 Report Share Posted July 11, 2012 (edited) Well the cutsheet makes easy for someone to get the job done without any calculations but you can come up with yours, the L port parts need to be done exactly as listed though. Having said that it is convenient to follow the cutlist since the subs will have much better support, also I am not showing the front to back and top to bottom bracing that is needed, if you would like me to update the drawing with that let me know. Edited July 11, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
simplemindz Posted July 12, 2012 Author Report Share Posted July 12, 2012 Wouldn't the L port measurements change now that the width of the port is 5.75? And yeah i would really appreciate it of you can redo the sketchup with the updated width and port wideness being 5.75 please? Also where it says the vb is 6 cubes, thats after port displacement right? Thank you i really appreciate it Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 12, 2012 Report Share Posted July 12, 2012 Wouldn't the L port measurements change now that the width of the port is 5.75? And yeah i would really appreciate it of you can redo the sketchup with the updated width and port wideness being 5.75 please? Also where it says the vb is 6 cubes, thats after port displacement right? Thank you i really appreciate it Ok, check this carefully: the whole cutlist has been adjusted to reflect the changes including the 5 3/4" port, ALSO the pic is just an assembly guide of generic dimensions, I have updated it to show the bracing that must be put in place. If you have further questions let me know. Quote Link to comment Share on other sites More sharing options...
simplemindz Posted July 13, 2012 Author Report Share Posted July 13, 2012 Thanks alot you dont know how much i appreciate this man. Thank you again if ii have any other questions ill let you know. Thanks Quote Link to comment Share on other sites More sharing options...
tbake223 Posted July 13, 2012 Report Share Posted July 13, 2012 joe isnt it bad tho for the "L" part of the port to interfere with one of the subs air space? thats why i designed my one std style but i believe you said it wasn't as efficient. my source is one of EXOs box building vids Quote 02 Ford Focus ZX3 hatch 4-Infinity Kappa 682.9cf's DC Lvl 4 Hifonics BRZ 1200.1 @ 1 ohm Kicker Wires Rockford RCAs Future Upgrades Knu 1/0 XS Power D1200 80 mil audiotechnix B stock Link to comment Share on other sites More sharing options...
Joe X Posted July 13, 2012 Report Share Posted July 13, 2012 That is usually a disadvantage of L ports but not in your case as the box is deep, you can always help more placing the subs as follows (remember the other pic is onla an assembly guide not the actual box): You won't have unbalanced loading like this. Quote Link to comment Share on other sites More sharing options...
Jeff E Posted December 18, 2020 Report Share Posted December 18, 2020 Hey Joe x I have a Chevy van so size don't matter I have one level 4 dc 15 on a Rockford bdcp 1800rms can you help with a design thanks Quote Link to comment Share on other sites More sharing options...
