The loudest song I have found on the meter is Moan by Lil Wayne Ft. Rick Ross. It was on a decaf zip. Its around .7 db louder then my next closest. I got some new ones I'm going to try at the next comp/test and tune
PSI 18 (soon to come)
Cactus Sounds Amp
Knu wiring
8k HID's
Most will say find a song were you peak..as for myself I peak at 37hz and it takes a ton of power to play that low..interesting enough my loudest song is airforces by jeezy it peaks at 41 and I peak at 155dbs with it
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i can play music just as loud as i can burp.. before my unloading issue i would use lil jon- push that nigga and could do a 155.1 havent been able to really get a decent number with new woofers tho.. its alot louder tho!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
You guys crush my score lol. I'll be up in the 50s one day. I peak around 40. I'm hoping to hit a 145 with the new port/amp.
Cactus Sounds Amp
Knu wiring
8k HID's
  • Who's Online   0 Members, 0 Anonymous, 690 Guests (See full list)
