So with the second battery I'm putting in my trunk I should just run my now power wire to the positive on my alt and use the run going to my trunk? & no big 3 would be needed then correct?
As of right now my 1/0 is attached right to the post on my fuse box where the alt drops power off to. Can I keep it like that and just connect to my rear battery cause how I see it its the same thing. Fused on both sides of course
Your best path to do this is to simply do a Big 3 (1/0 engine ground, 1/0 to your main battery, and 1/0 from your main battery ground to chassis)
And then to run a 1/0 from the main battery positive to your rear battery positive.
The whole point of a Big 3 is to in theory get maximum output from your alternator by increasing the wire size (causing less resistance)
Edited by jeffm4688
Team L.I. S.P.L
- DC XL 18 M2
- DC 3.5K
- Mechman 270
- XS & Shuriken batts
I plan on doing a big 3 in the upcoming week or two.
But ok it looks like that's what I'm going to do I already have a 0 gauge run going to the rear.
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
  • Who's Online   0 Members, 0 Anonymous, 1961 Guests (See full list)
