Hey I got a question, would a stock battery + a shrunken bt-120, with a 130amp alt powering everything be enough to keep a decent voltage playing my zx1500.1 running at 2ohms putting out around 1600rms.
Or would that still not be enough
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
It should be fine. Have you done the big 3?
1998 Ford Contour
Head Unit: Pioneer DEH-P8400BH
Front/Rear Door Speakers: Alpine SPR-68 (Type-R 6x8)
Door Speaker Amplifer: Kicker ZX650.4
Subwoofers: 1 SSA Icon 12"
Amplifier: MB.Quart 1.1500d
Second Battery: XS Power D925
For a little while yes. But in the long run you'll destroy that bt 120 mixing it with a stock wet cell batt.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
What kind of long run are we talking here...like 2 years?
I have not done the big 3 yet, I will once I order another 10ft of knu 1/0
Running Wet Cell and AGM together is not a good mix. Check out this. It's an isolator that you connect both bats and your alt to and charges each one individually so they aren't ran in parallel.
1998 Ford Contour
I'm guessing if I got that I would have to run a second run of 0 gauge
A second run to where? One run from Alt to the Iso, One run from the iso to the rear/second battery, then one run from iso to front battery.
1998 Ford Contour
