What should I use to brace my box? Are there some things that work better then others? Let me know.
Oh and I was also wondering what should the dimensions of my port be if my vehicle peaks at 46 hz? My box is around 12 cubic feet, one chamber, and I am doing subs up port near rear glass in the center of the box, and I just don't know how big to make it.
Edited by REVOK1NER
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
all thread is the best, then u have wooden dowles, and last 2x4's. that or u could just use a shit load of glass
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
What is all thread? And where could I get it?
-2.5% Tint
-2 18" DC LVL 4's
-Amps are undecided
you can get it at almost any hardware store, heres a pic to help u
just drill a hole on both sides of ur box run the rod through on the inside of ur box ur goin to put a washer and nut on it then on the outside washer and nut and just tightin all four nuts and ur box will barely flex, i recommend puttin some resin on ur nut and washer on the inside just to seal it off
Oh alright thank you, is it expensive because it looks like a really big bolt and I would need two that are around 40" long, any idea on price? Oh and any help on that port size anyone?
-2.5% Tint
-2 18" DC LVL 4's
-Amps are undecided
$9-$13 bucks for the all thread.
the port? www.reaudio.com (enclosure calculator)
www.subwoofertools.com
no link, sorry!
I try not to use bracing. Just double, triple or even quadruple your wood thickness if you're after SPL. Sometimes internal bracing can hurt.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
Exactly right. Sometimes bracing will cause destructive turbulence. Well what I should say, all bracing adds turbulence but some may not be noticeable at all. Some might totally kill your airflow, eg. if you put a big 2x4 in front of your port it won't be doing any good.
My Youtube Videos
  • 5 weeks later...
i 2 figure that 2x4s would hurt. which it does you can use the all thread rods they are round and has less resistances. and works way better than any other method. you can also add glass to the inside of the box to seal it off and 45 the corners as well (inside the enclosure)
  • Who's Online   0 Members, 0 Anonymous, 2410 Guests (See full list)
