good type of battery
i have a current XS power D975 hooked up to stock battery using 4 gauge wiring and the battery dies with in the day. charged it up to 11.7 volts this very afternoon, and i can already notice a huge drop in the performance of my subs. i have 2 skar audio VVX 12's and a 1500 watt power acoustik amp. i am looking for a change of battery, any feedback helps
2012 Silverado ext cab
Kenwood DDX470
XS D3400 (starter)
XS D375 (under passenger seat)
XS d3100
Mechman 240
Big three
SMD VM-1
All SHCA wire
80 sq feet of Damplifier
6.5 Crescendo CZ's (front doors) (needed)
5..25 Crescendo CZ's (back door) (needed)
Crescendo 125.4 (needed)
Sundown Zv4 12
Skar 4500 (2ohm)
sounds like you have more issues than the battery or batteries charging up to only 11.7 volts is not good at all you need to get your alty checked out, try unhooking the xs power battery from the stock battery one cloud be draining the other...
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
the xs is a sweet battery but 1: dont mix stock wet cell batts with anything other that wet cell batts, as with agm, gel, etc.
2: charging up to 11.7 is under what you need to be charging at. are you saying that your batt is resting at 11.7 or itss charging at 11.7? either way its not good for your xs to be sitting so low. get new alt or new charger.
EDIT: you should notice huge drop in performance with such a low voltage. im surpised you havent fried your amp.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
well i will only have this car for about one more year then im getting something bigger. in theory, if i got 2 more VVX 12's and a 3500 watt amp. what should i do for batteries. i will have big three, all 0 guage. and i am clueless when it comes to alts
Kenwood DDX470
XS D3400 (starter)
XS d3100
Mechman 240
Big three
SMD VM-1
All SHCA wire
Sundown Zv4 12
Skar 4500 (2ohm)
when you get to the 3500 you will need a high output alternator probably a few d3100 probably more 0 gauge
btw sounds like the alt is burnt up or a wire is shorting out or something is left on
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
  • Who's Online   0 Members, 0 Anonymous, 4757 Guests (See full list)
