Building a (Quite Baller) Game Box for around 1-grand
I just skimmed through and saw a comment about an overheating 470, I apologize if you felt I went after you.
I've been running an EVGA 470 GTX since release and did have issues with it getting hot at first. After I pulled it apart and replaced the thermal paste with Caramique (sp?), I havent seen it go above 65 degrees and its overclocked.
whats your clocks on it though?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
so about 700mhz.. well here comes the kicker for you.
im clocked at:
1.125V on the core
850mhz core
1700mhz shader
2000mhz memory
the stock this card comes with is:
.975V
656mhz core
1312mhz shader
1701mhz memory
the card im running is a zotac 470 AMP! edition. triple slot video card dual 92mm fans with the zalman cooler on it.
im sure this card could be clocked at around 900+ on the core but it gets too hot and artifacts with it at 900. (about 79C)
trust me i am SEVERELY pushing this card for what it is on air.
i can live with 850mhz on the core as a high level overclock on air. i never use it unless i benchmark or at lan parties.
the computer runs about 167 hours a week and relaxes at 36C on the GPU and the CPU.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
Well with voltages that high I'm not suprised to see high temps :) I havent even checked my clocks in a while, I know I didnt touch the voltage though. It still rips through pretty much every game at 1920x1080.
Yeah rips through games at stock clocks. I only push 850 and that high Vcore if someone is around. Nothin like hearing dual 92mms run at 3.9k
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
