Brian2435 Posted July 1, 2012 Report Posted July 1, 2012 I'm looking to make a ported enclosure for my vmax 15. In the manual it says that the internal volume for both the recommended sealed and ported enclosures are the same, 2 cubic feet. From my experience, I've always seen the recommended ported enclosures to be larger than the sealed. So my question is, has anyone had any experience with these subs and found/know if the 2 cubic feet volume for a ported enclosure would work? Or should I go with one a little larger... Quote
RAM_Designs Posted July 1, 2012 Report Posted July 1, 2012 Never ever go by factory recommended enclosures...they are 99% of the time not optimal at all. They'll tell you to use small boxes and small ports so that you can fit more of their equipment in your install, instead of giving you specs for a higher performing enclosure. Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
Brian2435 Posted July 1, 2012 Author Report Posted July 1, 2012 Never ever go by factory recommended enclosures...they are 99% of the time not optimal at all. They'll tell you to use small boxes and small ports so that you can fit more of their equipment in your install, instead of giving you specs for a higher performing enclosure. Alright then, do you suggest I use an enclosure software to design my box? Quote
