C1500 build. DC 9.0K, dual singer 350a, air suspension and Fi audio
I got the template for a member on here I will see if I have time to work on it. Might have to got to the junk yard to get the alternator casing.I know a shop that I used to get rebuilds from.might hit them up first
for sure bro hope it works out for u. Damn it must be hard working on 2 projects!!
working on 2 builds is not hard.. its inefficient, by the time you save money to finish one build you spend money on the other.. spent 2k on air ride last month and still cant get it done.. those 2k would have finished the car.. its an evil cycle i been dealing with
just received the last 2 valves.. these are SMC the other 6 are Parker valves. the Parker valves have been discontinued and no longer available. later on after im done with both builds i will start replacing the mismatch things.the parker valves i tried them out and they work so they will be used for a year or 2 maybe even 3. i want to get the builds done and getting new valves would be a setback
the older parker valves i have are much more massive and look beast. these look tiny compared to the parkers. i will be buying slow down valves in case some don't lift or lower evenly
18083_827154513988146_456166998301765746
11080916_827154523988145_309025149961928
11109707_827154537321477_525483680744101
11083655_827154547321476_199096528894337
just got done doing the mock up for the dual alt bracket. just need the casing to mark where the second alt bolt holes will go. i also have 8 steel plates that are 12x30x 1/4 inch hopefully that's thick enough.
thanks chevyboy for the measurements
1907647_827239840646280_5760828975452371
10456263_827239873979610_410892808761590
11094721_827239893979608_172753888486849
10999256_827239913979606_778085186958424
11026118_827239960646268_263489441167545
Kyle, i know you hate my balls by removing the singer from my impala. but i promise i will make you happy on this build
im liking the idea of dual singer 350a alternators. just needs to figure out where the second one will go and have the bracket built
11081380_826056344097963_295481751153239
Random questions. Whats the big ass pulley on the top left? What year is that block? My 86 454 has a way different configuration, now you got me wondering if I can retrofit a tensioner
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
the big pulley is the AC delete
the 454 came out of a late 1980's suburban.. the brackets and pulleys are GM performance aftermarket parts.. its not stock
