So i recent got some 1/0 knukoncepts wire, and some tsunami terminals. . . my only problem is after i installed everything, my car wouldnt start. if i hold the old wires on, then it starts. . . should i take off the old wire? (i left them connected and disconnected from battery, but had the 1/0 fromthe exact same spot to the bat so idk whats the problem)
It should work with your factory wires in place. That's how mine is now but I plan to remove all the factory wires soon. Make sure all your connections are good, your grounds are on sanded metal, and make sure your batt terminals are on tight. My truck didn't start once bc I didn't have the negative terminal on all the way.
Vehicle: 2007 GMC Denali
Headunit: Pioneer AVH-8400BH
Sub Amp: Rockford Fosgate T-1500bdcp
Sub: Ascendant Audio Havoc 12"
Electrical: Big 3, Dual Batteries, Stock 160-amp alternator
Wiring: RF 0 gauge
Box: Custom built 1.89^3 net
Did your Big3 include a run to the starter?
By removing the old wire you probly disconnected the starter.
Leave the old wires connected.
More wire never hurts!
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
ummmmmm you idk man. batt positive to alt, batt neg to ground, block to neg
would a short in the wires cause this to happen? does it just stop or does it spark when you try to do it
I agree. I think you might not have replaced the starter wire.
Wiring: RF 0 gauge
it just makes one click sound (cant pinpoint when in the car haha) so maybe it is the starter. . originally there was bet to engine. bat to chassis, bat to alt, and pos of bat to some fuse box. the ones i put back after big 3 are engine to bat and the wierd fuse block one. so im gonna see whihch one it needs (prob the fuse block thing0 and go from there. . . aside the fact. i still notice bad light dimming. id what amp is putting out a 2 ohms (american bass hd 3500) its 1600rms at 1 ohm but its at 2 right now. . . new sub this weekend will be at 1 ohm. will that make it worse?
Probably. What's your electrical look like?
Wiring: RF 0 gauge
I would put any money down that your power wire off the battery has a wire harness that splits to different places. When I did my Big 3 my pos wire has that, it goes into a wire harness and splits to a few different places. So I just ripped up that permanent battery terminal and drilled a whole on the side so I could fit it into my new terminal. From there I removed all the stock grounds and just replaced them since I know where they started and ended. That was the key to why I kept the pos, I didn't know where it all went, nor did I want to find out. Also for my car, there is a part off the pos harness that goes into the fuse block, so I had to keep it.
Edit:
The top wire off my pos is the old pos wire, you can actually see it has a few wires there going into it.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • Who's Online   0 Members, 0 Anonymous, 1407 Guests (See full list)
