yeah i'd stick to the 1500's until you can upgrade electrical, my guess is you're looking at drop to 10-11v if you were to run the 4500 at 1 ohm on your current electrical, i'd look into a 250amp+ alt and 3 XP3000's if you can fit them. My friends mazda 626 with a Excessive amperage 225amp, batcap 4k, and kinetik hc2000 was dropping to high 12's revved up on an RD3250.1 at 1 ohm and we still never maxxed the gain to it's highest clean signal.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Yeah I think I'm going to stick with two 1500's strapped if I decide to upgrade. Doing the math for a 4500, at 13v I would need 549.45AH's, even with my 220 alt I would need around 362.45 AH in battery reserve.
Strapping two 1500's at 13v will only require 384.6AH my alt will bring that number down to 195, and a bt 120 and 2 BT-20's will be nearly a perfect match.
Electrical is a bitch aint it.....:D
97 Suburban
8 custom PSI Platform 3 18's
Thank's for the input, there is NO more room except in the bay to upgrade batteries. And upgrading the front batter will force me to remove the BT-35 in front. I plan to keep my 5 seater car a 5 seater. If I didnt then for sure 4 xs 3100's in the back :D
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
Electrical is a bitch aint it..... :D
+1 and it doesnt help that batteries rate their cranking amps. I dont get how a bt-20 does 850 cranking amps? 20AHx14.4=288watts...so idk where 850 come from
Scion tC SQ Build
