Voltage drops to only 13.8.... Should be way more
and you tuned the amp with the dd1?
yep, turned HU up to 43/62 because the doors start to distort and theyre on a stock amp, so nothing i can do there. so then i turned up the head units sub level to +6/max, which is safe because +6 was safe up to 55/62. Then i turned up the gains....... wtf
in the headunits eq section (not the subwoofer level), do you have any of the bass frequencies of the eq lowered?
I guess i have to ask... What is the amp wired too?... Then after you say what load it is, are you sure? Lol
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
My gain is set with a DD-1 my HU bass knob is maxxed and its safe to do so via the DD-1
Subs definitely not hitting hard at all.. Why am i a noob?
Cant wait to solve this cause my headliner is getting raped and my windshield is bouncing like a whore already.
Why am i not drawing power? bad ground??
I could tell i couldnt draw enough power because i had no dimming on any lights, here is what I did
and walla hella light dim action, lol
I added extra grounds off the battery, then grounded the ground to an entire different are, the extra battery grounds worked so well, I figured it would not hurt anything to add that additional ground somewhere else, the reason I did not run that straight off the batteries is because I was out of room, (need bigger terminals
what track did u use for head unit and for amp tune
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
  • Who's Online   1 Member, 0 Anonymous, 1413 Guests (See full list)
