Question when setting a monoblock with a DMM
So the voltage I was looking for was 34.6Volts AC when setting my monoblock for 300 watts @ 4 ohms. My question is, I have all settings flat or turned off if possible. One thing I noticed, When I would adjust the SSF or LPF on the sub amp, which is not switchable on or off, just variable. My AC Voltage would fluctuate when moving the dial back and forth. If I want to set this amp, where should I put these at, highest Hz or Lowest? When I would put my LPF all the way to one side at 300Hz it would have a higher Voltage then when it was all the way at the bottom at 40Hz.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I'm assuming you are using a 50hz tone or close to that. So turn the ssf all the way down and the lpf all the way up. The lpf cuts off stuff above it so if you have it all the way down it will be -12 or -18db whatever the slope of your xover is.
Hopefully I got that right.
Team B2
2008 scion xb bagged on 18's plastidipped matte black
4 18" b2 xc's pushed by 4 b2 m1s at .5 each
8 b2 hn6's and 2 b2 hntt's powered by 2 b2 quattros.
157.7 sealed so far.
I use 40Hz, I actually tested AC Voltages from 100Hz all the way down to 25Hz, and they all produced the same amount.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 990 Guests (See full list)
