Sub for regular cab truck box behind seat suggestions
i have to sa 8v.2's............mounting depth i believe is 6 5/8.............still havent installed the box yet.(friggin heat) box is 36x14x5x11 with a 4 inch aero port.....should be around 36hz...........i have to make a spacer on the outside of box so aeroport is atleast 2inches from the sub...........if you can squeeze another inch at top and bottom im sure you could fit the SA in there...................but im no expert..................
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
op-what year truck and check my build loudest single cab no blow through.
You have the loudest single cab?
Not really though I still have yet to put on the TL, but it moves a lot of air for sure. Maybe close to some haire tricks.
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
i had a 83 c10 reg. cab and i built a box that was 48" wide, 13.5"tall 7.75" deep bottom, and 3.5" deep top, 2 seperate chambers, with 2" ports in each end, i used rf p2d28 without the magnet covers on, it sounded good.
these orphans aren't going to feast on themselves
