So my friend has a 04 Silverado and he has 2 12 inch kickers cvrs that he's wanting me to install in his truck. He's above 6 feet tall so his seat is almost to the back leaving me at about 7 inches from seat to back. I don't think there's enough room for both of the subs but here's the specs for space.
62-22-7
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Use behind the seat and extend it and port into the centre console
His girlfriend sits in the middle seat seat and refuses to sit anywhere else lol. I was going to build a box for the subs in the center but that's out of the question now.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
Ive got a thought!?! Some might not agree but an idea i had.
internal view
outer view can be changed if wanted
im not the experienced at box designing but i try and you got to start somewhere right?
hope this helps
The box looks like it would work but I'm not sure on the cubic feet needed or the subs. I'll have to look at the specs of the subs
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
I looked up specs for 2 12"CVR's and with the room you got this is as close as i can get.
2000 Cavalier 4 door
XS D925
XS D2400
XS D3100
4 runs of 1/0
Mechman 270
2 DD 9515js
What's wrong with that just tune it to the luck 33 and let her sit there
Where did you measure the depth? At the bottom of where the box will be or the top of where it will be. Just had to ask.Also, if they are the new cvr's , they have a mounting depthof 6 1/4 inches. So a 7" deep box will give you 6 1/4" depth to mounting them. So uh, yeah that will be close.
I measured closer to the bottom where the subs will be. It's a really tight fit but on the passenger seat I can adjust that seat if I was gonna do one sub and make a 1 inch mounting ring if that would even work
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
I was just worried about the incline of the seat back being closer than 7" Trucks are such PITA to do installs on. Nothing ever fits like you think it will.
If all else fails and you just cant get the sub in and get the depth you need see if he will entertain the thought of removing some plastic panels from the back wall of the truck and using the back of the cab as a back wall. I mean if you use a bunch of deadener and mayb...... no, ignore that, I'm getting ahead of myself. Best of luck with this.
