Just remove the remote wire your good
Make sure you do this tho haveing an amp sit idle for days is onne of the worst things you can do to an amo
Is that actually bad? If you have the gain down it shouldnt be a problem... should it?
yes, amps dont like having power and searching for signal to put out that just isnt there, i dont know the reasoning behind it, but i know they really dont like it.
it's kinda like having the microwave on without food in there. It's bad because it has nowhere to transfer the power to. engergy in = engergy out
Learned this when working on my system, class a/b amp without rcas plugged into it, got hot enough to burn my hand...
1997 Ford Ranger
2 - Rockford Fosgate P3 600w 12s
1 - Soundstream Rubicon 1.1000d
Pioneer Mids/highs
Blacked out tail lights (removable, done with 20% static cling tint)
makes perfect sense.
woman..cant live with em...cant shoot em...guess were all fucked
You might be a Redneck if you use your leftover gutters for a speaker box port...
YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
i would just tape up the wires, remove the fuse like stated before(from the battery to the amp).
and completely remove the amp. the wiring is fine if its just there protected, but if your amp is just sliding around it would cause a lot of stress on the wires and possibly ruining your ground cable.
well that was the case for me one time anyways...
dont matter, two bare wires cross and bamm
