Just remove the remote wire your good
Make sure you do this tho haveing an amp sit idle for days is onne of the worst things you can do to an amo
Is that actually bad? If you have the gain down it shouldnt be a problem... should it?
yes, amps dont like having power and searching for signal to put out that just isnt there, i dont know the reasoning behind it, but i know they really dont like it.
it's kinda like having the microwave on without food in there. It's bad because it has nowhere to transfer the power to. engergy in = engergy out
Learned this when working on my system, class a/b amp without rcas plugged into it, got hot enough to burn my hand...
1997 Ford Ranger
2 - Rockford Fosgate P3 600w 12s
1 - Soundstream Rubicon 1.1000d
Pioneer Mids/highs
Blacked out tail lights (removable, done with 20% static cling tint)
makes perfect sense.
i would just tape up the wires, remove the fuse like stated before(from the battery to the amp).
and completely remove the amp. the wiring is fine if its just there protected, but if your amp is just sliding around it would cause a lot of stress on the wires and possibly ruining your ground cable.
well that was the case for me one time anyways...
dont matter, two bare wires cross and bamm
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
