Swan99Hoe Posted July 10, 2012 Report Share Posted July 10, 2012 Ok so I feel like my system is not getting as low as I want. Could be because I'm running HDC3's and the suspension is tighter than a virgins pussy lol, could be because I'm under powering them badly, could be because of my tuning? I tuned it to 33hz, which I thought would be a frequency. But anyways the best song I've played in my truck as far as demo wise on the lows is Dorrough- Trunk Bang. I wanted to know what the low note was so I threw it in audacity. I took 2 screen shots (1 of the high peak and 1 of the low peak). Are these frequencies correct?? ^^^^^The high note in the song is 46hz^^^^^ ^^^^^The low note in the song is 31hz^^^^^ Quote Build Log: http://www.stevemead...deo-added-pg-3/ Youtube Channel: http://www.youtube.c...nRoyal76/videos ~Team Nussiance~ Head Unit: Sony MEX-BT38UW Amplifier: 1 AQ2200d for break in period Subwoofers: 2 AQ HDC3 18's Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets Scores: 148.1db @47hz 146db- Dash 143.8db- Headrest Both on music Link to comment Share on other sites More sharing options...
OrionStang Posted July 10, 2012 Report Share Posted July 10, 2012 Audacity is pretty accurate. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Guest Posted July 10, 2012 Report Share Posted July 10, 2012 you tuned the box to 33? wow you really must want to play 25hz on those subs. once the subs suspension loosens, they'll play better. what is your amps subsonic filter set to? Quote Link to comment Share on other sites More sharing options...
Swan99Hoe Posted July 10, 2012 Author Report Share Posted July 10, 2012 Audacity is pretty accurate. Ok cool Quote Build Log: http://www.stevemead...deo-added-pg-3/ Youtube Channel: http://www.youtube.c...nRoyal76/videos ~Team Nussiance~ Head Unit: Sony MEX-BT38UW Amplifier: 1 AQ2200d for break in period Subwoofers: 2 AQ HDC3 18's Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets Scores: 148.1db @47hz 146db- Dash 143.8db- Headrest Both on music Link to comment Share on other sites More sharing options...
Swan99Hoe Posted July 10, 2012 Author Report Share Posted July 10, 2012 you tuned the box to 33? wow you really must want to play 25hz on those subs. once the subs suspension loosens, they'll play better. what is your amps subsonic filter set to? Hell yea I want to be able to get low! To be honest with you I have no idea. I haven't messed with my gains in forever!! Quote Build Log: http://www.stevemead...deo-added-pg-3/ Youtube Channel: http://www.youtube.c...nRoyal76/videos ~Team Nussiance~ Head Unit: Sony MEX-BT38UW Amplifier: 1 AQ2200d for break in period Subwoofers: 2 AQ HDC3 18's Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets Scores: 148.1db @47hz 146db- Dash 143.8db- Headrest Both on music Link to comment Share on other sites More sharing options...
Baydestrian Posted July 11, 2012 Report Share Posted July 11, 2012 (edited) Yupp 31hz, steering wheel flex even on my 500rms lol Edited July 11, 2012 by Baydestrian Quote 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical Link to comment Share on other sites More sharing options...
BigPimpin91 Posted July 12, 2012 Report Share Posted July 12, 2012 Yes, 31hz is correct. Double check your SSF setting and see if it isn't set too high. Quote BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
Swan99Hoe Posted July 12, 2012 Author Report Share Posted July 12, 2012 Good call guys! My subsonic filter goes from 10hz-50hz. And it was turned like 90% up!! Quote Build Log: http://www.stevemead...deo-added-pg-3/ Youtube Channel: http://www.youtube.c...nRoyal76/videos ~Team Nussiance~ Head Unit: Sony MEX-BT38UW Amplifier: 1 AQ2200d for break in period Subwoofers: 2 AQ HDC3 18's Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets Scores: 148.1db @47hz 146db- Dash 143.8db- Headrest Both on music Link to comment Share on other sites More sharing options...
BigPimpin91 Posted July 13, 2012 Report Share Posted July 13, 2012 Well there ya go! Quote BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
