3 sundown 8's what size box?
the doesnt have to be on the same side as the subs...
For some that knows alot you design one
1st a 6" side ported box 35"w in max width of 35" is a sealed box with a hole in the side
So now the box need to be 29"w to allow fo port
So now that, sorted, you'll need more deepth then 19" because you shortened the width by 6"
2nd port length will be somewhere in the 28" length mark so you'll need to bend port so now yourv taken up 12" in the back, putting the port somewhere with 3-5" of sub with the opening facing the rear, and you'll have unloading issues with the port facing 1 or 2 subs
3rd to stop unloading you'll need to put 2x bends to make it 180deg, and then you lose the efficiency of an aero, witch is what allows you to use a smaller ratio
Gimme demensions of the trunk, i'll design you one:].
you just stated a lot of assumptions there just saying. we dont even know the demensions of the space hes putting it in to
OP posts his dimensions in another thread: 35"w x 11"h x 24"L.
and with the 00-04 mustang
im pretty sure 11" doesnt fit hard up against the rear of back seat
the roof need to tapered if you go over 10.5
from memory it goes up to 14" at 9-10" out,
i havent done a mustang box for a while as there not to common over here
edit
another thing to consider, most of these boxes will need to built in car,
i think 15-17" in deepth is the biggest you can fit, if constructed out side of car
Edited by john253a
fuck man cant you even read,
he's alrady posted them, and the car there going in
you're real cool.
thanks mang.
  • Who's Online   1 Member, 0 Anonymous, 1527 Guests (See full list)
