ok im gonna get a second batt but do i need a isolator if i wire them parallel and if i wire them parallel do they have to be the same CCA?
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
no isolator unless you are running stereo with car off
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
do the CCA matter on the second batt?
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
No, just as long as the type of batteries are the same ( ex. agm, wet cell, etc)
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
i dont believe so since i have optima under hood and stinger in trunk as long as they are both gel cell..some one may know for sure on that part tho
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
yheaa because i want to get a d1400 under my hood (back seat in a cadillac) and a D3400 in the trunk can i do so even with the CCA be different?
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
yes you can
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
umm ok so the car would only start with the first one? idk but ok thanks
My build
(2) Pyramid TW46
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
the d1400 is a 14 volt battery, meaning it charges up around 15.5-16 volts. Didn't know if you knew that.....but Id make sure your DTS electrical is okay with charging that high.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
You can not run a 12v and a 14v battery in parellel, they charge at different voltages.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2492 Guests (See full list)
