its a volume boost but i never thought of it like that ill just turn that off. But do you think the cone would be getting hot from clipping or from having shitty voltage? I know with my old subs before i had an alt and batt my cones would heat up pretty hot then once i did some voltage upgrades i was able to crank everything up and the cones didnt heat up once in 2 years of abuse
134db
where u from? can u get ahold of a dd-1 or a oscope?
REP
some amps dont like having there gains up maybe u need more input voltage
REP
ok come to the sound comp on the 15th at brentwood mall and ill set it for you
REP
ya july 15th july 29th and aug 26th for ones in vancouver
REP
where u live?
REP
So...low power at 2 ohms, guarantee you're lucky to see 1300 watts, and so the gain is cranked to compensate. Sounds like a recipe for disaster. You're only luck the sub you're abusing isn't run of the mill, assembly line subs, but a very stout performer or you'd have had burned shit long ago.
