LMAO I like the artwork on your box hahaha, it looks good man. Did you use torres box calculator to design your box
You can thank 97SSBlazer (Mike) for that beautiful artwork. I went to lunch and found that when I came back. But yes, I did use torres box calculator for this box.
Build In Progress!
2000 V6 Mustang
H/U - JVC KW-ADV64BT
8 - P3D212's / 14cu. ft. / 34hz
Front - T1675x2, PPS4-8x4, T1TSx4
Rear - T1675x2, T165x2
Sub Amps - T2500-1bdCPx2
Mids/Highs Amps - T600-4x2
3SIXTY.3 Signal Processor
51Ft. RF 1/0 Spool x 2
Excessive Amperage 300amp Alternator
VMAX CT2500 x 2
Optima Yellowtop
I know that I've been through this build before but I forgot if I saw the calc at all or not... my internets is slow so I didn't want to go through it again hahaha. and how were you planning on mounting subs
My idea was to double baffle with the second baffle going all the way from floor to ceiling and have it go around the center hump of the car. Hopefully that works...
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
that sounds good as long as they don't attach directly to the box, the soldered components won't like the box bump :P
LMFAO. My art work is the finesest around :) We use Torres and a little good old fashion noggin powa...
The majectic black cock has been proven in the Lansing area to add DB's and improve SQ, If you add a brightly colored port it also improves Box cooling and adds up to 15% more cone area..
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
I have the day off tomorrow, so I'm really hoping on glassing the baffle onto the box and getting the subs in for a test fit with a quick demo! Still don't have my Alt or all my batteries, so it will probably only be 1/4 of full power, but I just can't wait any longer looking at it without knowing how it sounds. I wired up the speaker wire today. 4 runs of RF 8awg to the outside of the bolts, and then 12awg wired up to each sub.
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
Get'r up and playin!
I wanna see this thing done and I can't imagine how bad you want to see the end result too
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
looks nice, what did you have before this wall?
Forgetting all the tiny systems that I did when I was 16, I have done 2 L7 12's on a T1500-1bdCP ported in the trunk, then 6 P2 10's sealed in the trunk on same amp, then 4 P2 10's in a blow through on the same amp. The blow through was by far the most impressive system that car had. The pics of that are in the beginning of this thread.
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
  • Who's Online   0 Members, 0 Anonymous, 3119 Guests (See full list)
