Mechman 270A low idle voltage/slippage
When I'm at idle, my charging light comes on, and my voltmeter reads around 11.2/8 (the engine sounds like it is about to repeatedly stall out). But when I am over 1500, it goes away and starts charging at 13.7. Me and Matt were guessing it was slipping somewhere- so I went and got a gatorback serpentine belt. Thought it would fix it, but to no avail. All the pullys look like they are spinning at the same speed. The overdrive pulley looks fast as well. My thing is what could it be? And if it is slipping, where? What can I do to fix? pleas help. i'm beyond frustrated....
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
Also, the tension is pretty tight, I'm not trying to strain any bearings....
I was suggested not to do this on an aluminum pulley.
under drive pulley is on the crank???
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Just the OEM crankshaft.
what car might help to know the model the voltage might be regulated by a computer
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
It is a 1996 lexus es300. Crank = 6", alt = 2' = 3:1 and redlines at 6000 RPM
have you left the battery unhooked for a while to reset the computer is there any wires you may have accidently unhooked
also check fuses
have you checked to see if the battery is still good/got it tested
Edited by deathcards
skar sk2500.1
alpine HU
2 x-15 sundowns
  • Who's Online   0 Members, 0 Anonymous, 707 Guests (See full list)
