maybe try that now with the JL's...... :)
I think the only downside really to my kicks is they really don't get "LOUD". They are clean as hell though. If you can fit the 6 and 4 in your door why not step up to an 8" in the door and pair of 5.25 components in the kick or A-Pillars. It'll give you a nice mid bass kick with that 8 and the 5.25 components will be more than loud enough. MPO.
I would try that but if I remove the 4" out of the door there is gonna be a hole where it was mounted.
Team Deadly Hertz
well i think im gonna try something im new at this so it might not sound that good but im thinking about an 8" and 6" dayton reference woofers ran off my amp on high pass or full the 8 is rated for 80 rms but since im not gonna be running lows im thinking of 90 to 100rms its strictly for mids adn the saame with the 6" 40 rms thiking of 60rms same setup full or high pass and a 4" shielded driver in the doors to help with the highs.and im thinking 2 3" drivers in each pillar to help for the front stage feel.i might do 2 7's like epicenters did i thinki it was them anyways
dayton 8"
Power handling: 80 watts RMS/120 watts max *VCdia: 1.5" *Le: .50 mH *Impedance: 4 ohms *Re: 2.9 ohms *Frequency range: 40-2,000 Hz *Fs: 42 Hz *SPL: 92 dB 2.83V/1m *Vas: 1.08 cu. ft. *Qms: 2.55 *Qes: .60 *Qts: .49 *Xmax: 6 mm *Dimensions: A: 8-3/4", B: 7-3/8", C: 3-1/2".
dayton 6"
Power handling: 40 watts RMS/65 watts max *VCdia: 1" *Le: .50 mH *Impedance: 4 ohms *Re: 2.9 ohms *Frequency range: 50-3,000 Hz *Fs: 55 Hz *SPL: 92.0 dB 2.83V/1m *Vas: .41 cu. ft. *Qms: 2.75 *Qes: .48 *Qts: .41 *Xmax: 4.4 mm *Dimensions: A: 5-15/16", B: 4-13/16", C: 2-3/4".
4" shileded driver
Specifications: Power Handling: 30 watts RMS/60 watts max *VCdia: 1" *Znom: 8 ohms *Re: 6.0 ohms *Frequency range: 65-16,000 Hz *Fs: 65 Hz *SPL: 88 dB 1W/1m *Vas: .22 cu. ft. *Qms: 3.32 *Qes: .43 *Qts: .38 *Xmax: 3 mm *Dimensions: A: 4-15/16", B: 3-3/4", C: 2-7/8".
3" driver
Specifications: Power Handling: 12 watts RMS/25 watts max *VCdia: 3/4" *Impedance: 8 ohms *Re: 6.6 ohms *Frequency range: 110-20,000 Hz *Fs: 110 Hz *SPL: 86 dB 1W/1m *Vas: .06 cu. ft. *Qms: 4.99 *Qes: .67 *Qts: .59 *Xmax: .5 mm *Dimensions: A: 3-3/16", B: 3-1/16", C: 2-1/4".
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
Guest MegaloManiac
if you want a baddass 3"mid(well technically 3.5") try out the TG9 by peerless. cant beat $60 for a pair. They supposedly outperform the Hybrid Audios l3 in an enclosed application. you could even run them without a tweeter if you really wanted to and it would sound fine for the most part.
welli want my 8's for just vocals and i want the 4's to bring out the rest like the higher sound and tick but still getting my vocals through them and my tweeters are there for the extra lil tick but i might just put another mid in the a pillar im just wondering if its gonna work before i do it lol
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
Guest MegaloManiac
8s are supose to for the midbass around upper 50s-249hzish, 4" mids should be around 250hz-2500 for the midrange aka vocals, tickers should be 25k on up
yea i know but i dont want any midbass i just want the sound but most speaker sets i heard were set as more highs and i just want the vocals really so im think im gonna try it it'll be like a house setup a mid bass a midrange and a tweet so it should be ok i guess
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
Guest MegaloManiac
no midbass <_< then a 3 way set is unnecessary, you can achieve what you are asking on a 2-way set, shit you could even do a 1 way set with them tg9s i told you about run them at 200hz on up and it will sound like you are asking
well then thats what im looking to do is a 2 way then will the crossover on my amp work or should i get a different one first time setting up something this complex
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
