Eric B Posted January 7, 2008 Report Posted January 7, 2008 Alright, heres how it goes. I just purchased 3 RF T10001bd off of Randy. I'm going to be running them at 1ohm each to each sub (still undecided) so assuming they all do 1500, ill be running 4500wrms total. I think the biggest alty for my car 200A and Ill run 2 runs of 1/0 GA and do the Big 3, what kind of batteries yall think I should run? Input appreciated 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
Eric B Posted January 7, 2008 Author Report Posted January 7, 2008 Kinetik 2400s or powermaster d3100s well could one do the trick or what, I cant really afford 2... 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
Guest Nismofreak Posted January 7, 2008 Report Posted January 7, 2008 aleast 1 yellow top and 2 or 3 1,400
audiofanaticz Posted January 7, 2008 Report Posted January 7, 2008 The amps should draw around 450 amps. One Powermaster D3100 (close to the amps), stock battery upfront, 200amp alt, 2 runs of 1/0 ga, and the big 3 should be enough to keep them amps satisfied for a while and then some.. Oh and the Powermaster D3100 is cheaper then the HC2400 because it has free shipping.. http://www.jegs.com/webapp/wcs/stores/serv...10002_794060_-1
Eric B Posted January 7, 2008 Author Report Posted January 7, 2008 The amps should draw around 450 amps.One Powermaster D3100 (close to the amps), stock battery upfront, 200amp alt, 2 runs of 1/0 ga, and the big 3 should be enough to keep them amps satisfied for a while and then some.. Oh and the Powermaster D3100 is cheaper then the HC2400 because it has free shipping.. http://www.jegs.com/webapp/wcs/stores/serv...10002_794060_-1 So you think Ill be straight with that setup you said? Because thats wat I planned on doing...and maybe upgrade a lil later... 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
audiofanaticz Posted January 7, 2008 Report Posted January 7, 2008 Most deff! D3100 puts out 3200 max amps. If you get a 200amp alt it will keep your d3100 and stock batteries charged and then some imo.
