Voltage drop problem BMW 325i
After installing Singer alternator, I have a problem with weak tension and belt slip. Right now I have stock pulley on, but also got a smaller one.
What happens is at idle it would charge at 13.7-13.8. When I rev engine up to 2k rpm it would go up to 13.8-13.9, but as soon as I let go gas pedal it would dip down to ~11v and climb back to 13.7-13.8.
I talked to Mike and he told to get a smaller belt and add another idler pulley. The problem is I don't have room for another idler pulley. I order a new smaller belt (stock is 60.5 and the one I ordered is 58.5).
What else can I do to get a better grip and tension?
What pulley did he ship. It with?
What's your car idle at?
Why are you only getting 13.9 out of it
There are more issues than a belt there
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
He shipped it with 2 pulleys, stock(bigger) and a smaller one. Right now I have stock on.
Car idles at ~600-700
I don't know why it charges at 13.8. I asked Mike about it and he said that's just how some car work. Before, with old alternator, it would be charging at 14.0-14.2. He said that in order to get a higher voltage I need to put a smaller pulley on and drop a belt size.
The only thing I added was 1 run of 0 gauge wire running from alternator straight to back battery. (fused) along with the stock wire too.
They make a hydraulic tensioners for some of the bmw's, i just did a quick google search and another forum came up with it.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
The thing I don't understand is why does the voltage drop so low after I rev engine up.
My 320A Mechman spikes up to 15.5V when I punch the throttle but never drops below 13.8V (warm) when I let off the gas and drop to idle.
Given I have an adjustable voltage module with it but it sounds like you may have a flaky voltage regulator of you're dropping in the 11's by just letting off the throttle. :shrug:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
How did you installed yours?
Took out the stock alt and just installed the Mechman with the pulley that came with it.
I left the stock control header disconnected. It came with an adjustable voltage module instead that I ran to a relay that's switched by my ACC wire.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
The pulley it came with is smaller right?
I tried both pulleys, stock and smaller one, and can't get the voltage to stay where it should be.
  • Who's Online   1 Member, 0 Anonymous, 1283 Guests (See full list)
