It shouldn't be any different than doing the Big 3 on any other car if you're doing the fundamentals. You're just adding a couple of grounds and an alternator to battery cable. How is the alternator currently wired to the battery?
Alpine CDE-164BT/Rockford Fosgate P400X4
Kicker CS 6.5" Components (Front)
Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage)
RF P400X1 Monoblock
2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box.
Well the 2 awg wire that runs from my battery to the alternator turns into some 8 awg wire so I have heard on a forum. And I was just wanting to know if some people knew anything about this and could confirm it. Im sure that's why my lights dim. Another thing is that my factory battery ground only runs to the chassis, Should i just run some 0 awg wire from my battery ground to an engine ground?
Just run a fused 0G in ddition to your stock wire from the alternator to the battery, that's what you should be doing anyways.
Ground your battery to a strut bolt for a solid ground. Then, add a ground from your engine to chassis, as well. This will give you very solid grounds.
RF P400X1 Monoblock
Thank I'll do that as soon as possible. I appreciate your help
  • Who's Online   0 Members, 0 Anonymous, 2125 Guests (See full list)
