amp sooooo hot
PardeTime
Turn bass boost to 0db and see what happens, set the LPF to as close to say 80 as you can.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
One more fast question. Store sold me amp said it was OK to drop to 4 gauge after second battery. Amp won't take 0 gauge...is this possibly a problem?
since you cant fit any bigger wire, 4 gauge is fine. amp fuse is 150 amps, which is suitable for 4 gauge to handle
100 amp fuse for an amp that requires a 150 amp.
half gain means literally nothing. you could very well be clipping the living shit out of that amp, but no one will know if the amp wasnt tuned with the proper equipment
Earlier:
"Half-way" does not mean unclipped, either.
I'm with Kranny.
I'm gonna hate
Double check all connections to make sure there are no loose connections.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
So is the dd 1 "proper" tuning equipment? Because that's what a buddy of mine has...or is more needed?
that should be the only piece of equipment you need.
Fuse is not helping, but its not a large issue.
Your daisy-chaining of power and ground cables is a bit more worrisome. Have you done the "big 3" or are you just hoping where your power is coming from and where your ground goes to are half-assed from stock battery?
Can you tell us how you wired the subs so we know you're actually at 1 ohm?
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 2343 Guests (See full list)
