amp sooooo hot
PardeTime
Would the fuse be causing amp heat? And I know I will tune amp with smd thingy tomorrow. I just finished install and wanted to hear it. So setting everything but the gain to 0. Sounded loud as he'll but very hot.
possibly. when you start pulling enough current to get to the rated point of the fuse, the internal filament will start to heat up, causing resistance in the power line. amps HATE resistance on the power side. causes major voltage drop and heat
edit: someone correct me if im wrong, but thats what i've learned
Yes. Fuse your wire properly.
Alpine CDE-164BT/Rockford Fosgate P400X4
Kicker CS 6.5" Components (Front)
Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage)
RF P400X1 Monoblock
2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box.
That's pretty much correct. It's like you're putting a choke on the wire. 0 Gauge, I typically fuse at 150A-250A, depending on application, but 100A to a 150A amp is definitely not optimal.
RF P400X1 Monoblock
<a href=http://s1069.photobucket.com/albums/u465/pardertime/?action=view&current=20120716_001725.jpg target=_blank><img src=http://i1069.photobucket.com/albums/u465/pardertime/20120716_001725.jpg border=0 alt=></a>
<a href=http://s1069.photobucket.com/albums/u465/pardertime/?action=view&current=20120716_001932.jpg target=_blank><img src=http://i1069.photobucket.com/albums/u465/pardertime/20120716_001932.jpg border=0 alt=></a>
<a href=http://s1069.photobucket.com/albums/u465/pardertime/?action=view&current=20120716_001744.jpg target=_blank><img src=http://i1069.photobucket.com/albums/u465/pardertime/20120716_001744.jpg border=0 alt=></a>
get the proper sized fuse, and report back.
how do you like those pro series woofers?
One more fast question. Store sold me amp said it was OK to drop to 4 gauge after second battery. Amp won't take 0 gauge...is this possibly a problem?
Might want to set the Subsonic to 20-25hz and LP set to around 80hz? That caught my eye first. Maybe those settings are causing a little heat?
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
  • Who's Online   0 Members, 0 Anonymous, 7739 Guests (See full list)
