amp sooooo hot
PardeTime
One more fast question. Store sold me amp said it was OK to drop to 4 gauge after second battery. Amp won't take 0 gauge...is this possibly a problem?
since you cant fit any bigger wire, 4 gauge is fine. amp fuse is 150 amps, which is suitable for 4 gauge to handle
100 amp fuse for an amp that requires a 150 amp.
half gain means literally nothing. you could very well be clipping the living shit out of that amp, but no one will know if the amp wasnt tuned with the proper equipment
Earlier:
"Half-way" does not mean unclipped, either.
I'm with Kranny.
I'm gonna hate
So is the dd 1 "proper" tuning equipment? Because that's what a buddy of mine has...or is more needed?
that should be the only piece of equipment you need.
Fuse is not helping, but its not a large issue.
Your daisy-chaining of power and ground cables is a bit more worrisome. Have you done the "big 3" or are you just hoping where your power is coming from and where your ground goes to are half-assed from stock battery?
Can you tell us how you wired the subs so we know you're actually at 1 ohm?
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 7224 Guests (See full list)
