SMZ2's Xterror. 1st Hairtrick!
theres tons of those brackets at lowes bro.................................but you could just buy some iron and make your own and its about half the price as that bracket.... they have that as well at lowes
So they are expensive there too? I work at a fab shop so I can probably make it at work if anything... sorry not trying to be cheap but this box is killing my monies haha
Hey man the port is to close the roof I just metered and lost close to a decibel from my old box. Is there anyway you can tweak the box to have the port fire forward? The top piece is only glued on not fiberglassed so it can be removed if needed...
I figured that might be a problem. didn't realize how tall the box was going to be. I'll get on the front firing port now.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
no need to remove the top. you can plug the port hole and cut open the front
More box builds
Can't wait to see some vids of this thing! lookin nice man
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Dang man that was quick man! So I'll be able to use the old port to get the sub out?
Here's option 1 for the front firing port. by putting the ports off to the side, that should eliminate any unloading issues you might have since the sub is firing directly forward.
I've got one more in mind.
More box builds
Yeah, if you want. you can just put another piece of wood over the top of it and remove it when you need.
More box builds
