KenC210 Posted July 18, 2012 Report Posted July 18, 2012 http://www.sonicelectronix.com/item_4993_Scosche-SLC-4.html so i was thinking about getting this to put a amp and sub in my car, but the only thing im worried about is that it says it only accepts 80watts per channel. Now my thing is that more than likely i will be putting a lot more watts per channel so is there anything i should be worried about or will it be just fine. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Ray Posted July 18, 2012 Report Posted July 18, 2012 80watts of input to the piece. Your fine. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
KenC210 Posted July 18, 2012 Author Report Posted July 18, 2012 Alright so i am going to replace the speakers and fabricate a box for a 8" sub with a 5 channel amp. http://www.sonicelectronix.com/item_44461_Crunch-P1-5050.5.html this is the amp im may get. So would i still be of if i used an rca splitters and this much power from an amp on that line out convertor? And this is why i dont want to replace the head unit... Its a navigation unit from a tundra that i put into my wifes 2012 corolla Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Bump4life Posted July 18, 2012 Report Posted July 18, 2012 yes. understand how a LOC works. it takes in a high level or powered signal (up to 80 watts running continous power) and outputs a low level (1-4volts) rca signal that goes to your amp. your amps power output has no limit if connected to LOC. it only receives signal from the LOC. Your head unit most likely puts out somewhere areound 20 rms so you are 60 rms under the max power your LOC can take before it burns up. edit: oh wow thats not even aftermarket head unit, you might be getting 10 rms out of it depending how good it is. and also if you are running a 5 channel amp make sure you get a 4 chanel LOC or 2 2 channel LOC. Personally i have never heard the one you are looking at but I run 2 PAC SNI-35 and they sound great. I had to crappier ones before and they sounded like crap. and make sure not to peg gains when you set. it will introduce distortion and clipping into system Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
