how to wire 6 10s
ZachG
3 15" cone surface area = 2670 square centimenters.
6 10" cone surface area = 1980 square centimenters.
If you want efficiency is easy to see where to go.
if you are asking this question on here I don't feel you need to run 6 subs or it would just be a waste of time. are you building a box for them? how much power too? usually when people do bigger builds they have done some research before jumping right in. this is kinda basic. not trying to be a dick but are you really prepared to do a build with 6 subs?
I'm aware of what it takes to do 6 subs, I'm just trying to ask and recheck what I think.
The point of this build for me is I'm getting rid of my 2 zx1500s & my 4 12 cvxs and going with a lower wattage system with more cone and motor. I've been wanting to do this, I'm staying around 1k rms.
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
The point of this is to stay under 1k rms.
& If I run 2 amps I will do 3 subs in a seperate chamber then the others and get a second set of rcas
I think it would be cheaper to buy one amp that does the power you're looking for at 2ohms instead of getting 2 1ohm stable amps. If you were running a lot of power then I would definitely suggest 2 amps strapped together
here's a great example, 1000wrms @ 2ohms. or to account for the 2.67ohm load you might want to get an amp that does 1200wrms @ 2ohms instead?
http://www.sonicelec...ONX1.1500D.html
Edit: doesn't have to be strappable like Emmet stated
ok. what 10s are you using? 1k or less is not that much for 6 subs. will they be able to move? your going with a sub rated 300 or less?
edit: go with 1 amp. after rise and impedence rise you will be closer to 1 ohm. for example my D2 DD9512s are wired to .5 nominal but they read .8 ohms before rise when i measure them. what looks good or bad on paper is not real world results.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I do want efficient on small power. But I just have a question about that. Other than the box problems that creates for me with 6 10s wouldn't I have more motor driving force than 3 15s?? That's how I see it
Depends on the subs.
I am planning on going with 6 kicker comp 10s, 150rms ea they say. I'm planing on those cause I can get em for like $40ea New cause of where I work discounted
Oh my bad I would be talking kicker comps for the 10s cause how cheap I get em, 40$ea New. Unless anyone has any better suggestions on subs for under 1k rms but my goal is most efficent here
im on board with this. but why 6 10s? if your looking for punch i think more cone area will hwlp you in addition to bigger motors. yea you have 6 smaller motors but 3 bigger motors will be more forceful if you went with 15s
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
